- Joined
- 21 Jul 2007
- Messages
- 237
- Reaction score
- 5
- Country
A bit of a strange one...
Recently I have installed a few extra sockets (7 doubles) in the stud walls upstairs. The sockets were run with a view to extend the ring main at the single socket on the landing. One leg was going to pulled out and Junction Boxed, and the other pushed up the stud and into the socket. Hey presto...
With the old socket apart (stranded uPVC) the ring was present i.e Neutral to Neutral, Live to Live etc. Also there was a 2.5mm T&E running off to a spur socket in the lounge.
Carrying out a voltage check prior to starting work, I noticed that the neutral from the ring to the neutral of the spur kicks out a DC Voltage on the Fluke. Unsure how much, as the fluke only has lights and not a gauge.
Afterwards, when its all put back together prior to turning power back on, I carried out a continuity check beftween Live-Neutral, Live-Earth, Neutral-Earth. Both Live-Earth, Live-Neutral and Neutral-Earth show continuity. Live-Earth was more of a chirp than a solid Live-Neutral due to appliances still plugged in etc. I think that's one for the morning...
Anyhows, DC Voltage in the picture below? A bit of a random one. I had thought it could be one of the many phone chargers, or the alarm panel battery etc discharings...
However.. when the lighting circuit is pulled the DC Voltage goes away. Looking at the Spur, the only thing that is close to it lighting purposes if the wall lights... Mrs FTB assured me that the wall lights were turned off..
Cant see how 2 lighting circuits borrowed neutral will matter, as the house only has 1 lighting circuit...
