Can someone tell me if I'm going crazy here!
I've just removed a set of spotlights from a ceiling and replaced with a standard pendant as it''s getting plastered.
It's the last pendant on the circuit so only one feed wire in however I'm convinced the 'Neutral' circuit wire was terminated into a terminal block and not connected to the light fitting in any way! Would the light still have worked this way i.e. with only the switched live connected to the light fitting or have I imagined it was wired this way!
