Hi All
I've just moved in to an old house and have got really loud pipes. When the heating is on there is really loud water rushing noises coming from pipes that lead down from the loft and in the airing cupboard plus pipes near the oil fired boiler downstairs.
I have a grant vortex eco oil boiler and also upstairs I believe the pump is a gundfos ups 15-60 130. Some of the radiators take ages to heat up. So my questions are:
1. what could be causing the noise? And what can i do to sort it?
2. the gundfos thing has 3 settings on it, it is currently on 3, what should it be on? And what does it actually do?
3. the hot water tank in the airing cupboard has its temperature set to 58. Is this the correct temperature for it?
4. the boiler has a heating temperature knob - should it be in a certain position?
5. I presume for the radiators I should just balance the system?
Thanks in advance
Thanks in advance
