I am trying to get to grips with the central heating in my new (old) house.
The hot water cylinder as the standard heating indirect coil entering / exiting at the bottom of the tank, it as pipes connected but I am fairly sure they ultimatly do not connect to the central heating boiler. There are however 2 15mm conections to the top of the tank, where the imersion heater would normally go, it looks like these are a feed and return from the boiler. Is it possible that this is a heating coil, and why would it be used instead of the stanadrd coil.
I should say that the heating circuit as been converted from a vented to pressurised system fairly recently by the previous owner, aparently to improve efficiency.
