- Joined
- 5 Jan 2016
- Messages
- 234
- Reaction score
- 8
- Country
Looking for a lil advice!
We had a new 25mm mdpe pipe installed with a bbox, this was tapped into the lead further up in our property so its still on a shared supply, although flow is much better!
I just wanted to know, is there any point in swapping out to a 22mm 1/4 full bore valve vs a normal 15mm one? I only ask because the mains cold runs to the combi are going to be 15mm, this is tee'd off further in the house where the combi boiler is. The boiler and washer is in a utility cupboard 7 meters away from the incoming supply.
What i was thinking was, 25mm mdpe to a 22mm stopcock under the sink, split the 22mm up into two 15mm feeds, one for the boiler/utility, the other for upstairs bathroom. Im not sure if i would gain much.... just thinking
