there is a brass cylinder, about 20mm dia x 75mm high, with a little red screw cap on top - I am told it is an air vent - sorry my camera does not work - it is fitted on a riser from the primary feed to the cylinder.
I formerly had a vent there that I could unscrew with a bleed key, but it never got any air in it.
I ask because I sometimes get the noise of bubbles going through the boiler shortly after it starts. I have topped up the inhibitor and bled the rads and verified it is not pumping over.
I also have an alpha+ pump if that matters.
Pump, valve, three port and all controls were all new in Sept when the boiler was changed. Syst is very clean. Syst is Vitodens 100 Compact open vented with cylinder. I recently cleaned bacterial slime out of F&E and added fernox AF-10 to the clean F&E.
Inhibitor is sentinel X100 which is recommended with my Permutit Water softener
