Hi All
I've just replaced an old Veritas 8 Compact control panel with an ADE/Honeywell LogicSix (with built in key fob) but its the same as the Gen4 etc - https://www.security.honeywell.com/uk/documents/Logic 6.pdf
I've got everything working apart from the external bell box. First of all, it appears the old installers joined an 8 core cable somewhere I can't get to right now, so it's not easy to see what colours are feeding what at the control panel end. I took a photo of the old control panel and wiring before taking it out. The installation has:
1 bell box (no strobe, just siren)
1 PIR
1 Door sensor
1 Window/glass sensor
They have used red/black for +12/0v respectively, so that's ok. I get power to the PIR and window sensor ok. The other 6 cores are:
2 for door sensor
2 for window sensor
2 for bell box
It looks like they have joined the 12v (hold +) and 0v (hold -) from the bell box in to the same red/black that is being used for the PIR etc. Is this normal, or a problem for the ADE?
I know on the ADE it has T A D B for:
T - return
A - 0v
D - +12v
B - bell trigger
The Veritas control panel only had B connected for the bell trigger, so on the ADE control panel I've left the jumper link in between T and A, left D empty and wired the bell trigger wire to B.
This all appears to work, until you set the alarm. As soon as the system is set (after the exit timer), the siren goes off immediately, until you un-arm the system.
Does anyone know what I've got wrong?
Thanks,
James
1 PIR
1 Door sensor
2 for door sensor
2 for window sensor
2 for bell box
T - return
A - 0v
D - +12v
B - bell trigger
Thanks,
James
