I have an integral garage which I'd eventually like to convert, but for the time-being I just want to knock-through a new external door, and split the garage into two. The rear of the garage will be used as a utility room (with only external access) and the front with the garage door will remain a storage area.
When I do eventually convert the whole thing, the rear will remain a utility room and the front will be a play-room or something similar.
Here is my high-resolution and very technically detailed diagram of our garage as it is now:
As you can see... Both the electric box/meter and the boiler are where the new door would ideally go.
If we put the door beside the electric stuff, then this will happen:
... We'll end up with a much bigger utility room than we need, and when we eventually convert the entire garage the play-room will be tiny. We want it the other way round, with a small utility room and a big other room.
Looking for some opinions about what we can do. It's a new-build house, if that makes any difference.
Ideally - the electric stuff and boiler would be moved to the back wall (through from the kitchen) so we can put the new door at the back of the garage where the boiler is currently... But I'm guessing moving the boiler to an internal wall will be expensive, and is it even possible to move the electric stuff or will the electric provider say it has to stay where it is?
