I am fitting a new bathroom and would like advice on:
1. The mixer shower requires even pressure inputs so do I need 2 x 22mm hot and cold or would 22mm hot and 15mm cold (from loft tank) do?
3. Currently all cold is mains. Which taps should have cold from tank?
4. The basin has a combo tap - should this be tank supplied (not mains)? But then it's not drinking water!
5. Should the loo be mains (or tank cold to reduce condensation on the cistern)?
