New bathroom taps on old copper piping
RKB
22 Jun 2004
Sorry to ask again, but don't want to screw this job up for ma in law.
1. She has bought a bath /sink/toilet from Bee and Queue, so the taps (new) will be current size - is that 22mm or 3/4"?
2. The house is an ex council of circa 1960, so I think the the larger bore pipe be 3/4" not 22mm.
The question - If the taps are 22mm, do I need a 22mm to 3/4" converter to connect up (I was going to go tap - 22mm stub - converter - original pipe)?
or will a 22mm compression joint take account of any difference?
Thanks in advance..
Thanks Kevplumb.
Guess the next step is to get stuck in :)
Not quite sure what Kev had in mind.
If you use a 22mm compression fitting on 3/4" pipe you need a different olive - they're sold separately, (at what always seems a high price!).
If you're going to use solder fittings they will not fit, you do have to use a converter to go to 22mm pipe.
