If the existing ones are 1/2 inch BSP, you can remove and replace them with new. The old ones can be in very tight.
If they are straight into the steel of the radiator, you may be able to drill and tap to 1/8 inch BSP and screw in a vent valve purchased from a merchant.
Is it the answer I'm after, basically i think you can drill it straight into the rad although as i'm not a plumber i'm not overly sure whether what you are suggesting is similar to the link??
Do people really use those auto vents on their rads? At 12 quid each (inc. P&P), it would cost me £144 for my 12 rads. Just so I don't have to bleed my rads once a year? Then they need to be replaced after approx 4 years.
