Well, my old Myson Economist WM30/40BF gave up the ghost today. I think partly due to it overheating when the F&E tank ran dry
Anyway, what I want to know please is if a suitable replacement for this old boiler would be an Icos 15 HE ? I can get one of these for about £600 or so & a mate who's CORGI reg said that if I hang the boiler, fit the flue & alter the Water pipework to suit the new boiler connections, he will sort out the gas connection and fill & test the system for a discounted rate.
Needless to say, I could be saving a packet here but I just need to know if that boiler would be OK. If it helps, my house is a two-up two-down terraced, two double 500X1200 rads, two double 600X1200 rads, a double 400X600 rad and a single 500X1200.
The old Economist ran these perfectly OK ( used to take it about an hour to get the rooms up to 20 deg in the morning ) & by what I can see on the ratings, the Icos should be about the same.
Thanks very much guys
PS - forgot to add, the Economist ran via 15mm gas pipe & I really don't want to have to destroy the ceiling to run a new 22mm pipe. Will this be a problem ? The total pipe run from the meter is 8M & the first 3.5M from the meter is 22mm.
