Hi all,
I need to move from a electric immersion tank system to a gas boiler.
At the moment there is no central heating system at all- the immersion heater runs the taps and shower, and a log burner heats the house separately.
I have been doing the house up for a year now and its coming along nicely, but have found plumbing to be the toughest job so far. after having made an error on buying the wrong shower pump (no head, so needed a negative pressure one) and getting a cold water tank as the shower was previously just gravity feed- I give in- I just need a combi or similar.
So what should I get? The house is a 3 bed semi and is VERY energy efficient (u value of about 0.3 over all)- but not enough to go without heating.
The shower needs to be quite high flow as its a large rain head thermostatic one- which means I need a high flow boiler?
I can pick up a boiler on ebay cheap, and I want to get an engineer to fit the boiler to run the shower and taps, and I will fit the rads later- can I do this? The gas supply is just round the bend from the boiler location, so not too bad.
I would like the option of adding the log Burner into the system at a later date and understand you can get combi's that accept preheated water??
Is this a bad idea?
Any advice welcome!
Is this a bad idea?
Any advice welcome!
