Am I right in thinking that a 15mm gas pipe going in to a combi boiler is illegal now?
Just my current 20 year old (ish) combi boiler is on its way out, and I need a new one. One plumber came round, and didnt check the existing pipework, and quoted £1700 which I though was far too much for a straight (ish) swap, even he said it wouldnt be too hard to do.....except maybe the flue to the roof, as its high.
The second plumber came, and checked pipework, pulled the washer etc out, and he said that there is 15mm pipe going in to the boiler which is now illegal. Plus wouldn't give me the required flow of gas, which I'm not sure he's right as at the moment I can have the cooker on, run a bath, and have the heating on with no problems. He checked the meter which is two grounds below, and said it starts in 22mm, so obviously changes to 15mm at some point. Its going to be a real pain taking the carpets and floor boards up, especially as its communial stairs etc.
Is there an easy way round this, or is he being a good plumber?
Also, as a rough estimate if you dont mind from the plumbers......how much for a new boiler for a 1 bed flat, with 4 rads. I thought maybe £1200ish, but the 1st quote I got was for £1700 which seemed quite steep.
