Hi folks,
I'm thinking about replacing my boiler myself. Before I start I know this has been discussed many times and don't want to start another unnecessary thread on diy installs. I count myself competent (to avoid starting another thread I'm not going to list why) and will be happy for the courts to decide on it. (But they won't need to because it will be installed correctly.) I've read thorugh the building regs etc and know exactly what to do to ensure it meets all the regs & manufacturers requirements etc etc) So with that said.....
My question is, I need a Gas Safe engineer to commission it. I don't have the equipment to run the tests obviously and get the building control paperwork (required when we sell the house soon.) So I'm looking for someone to come out, connect the gas pipe which will be sat right there ready to be connected to the boiler, and then commission it & register it with Gas Safe for the paperwork.
I know some engineers aren't keen on it (totally understand & respect this).
Question is are any of you willing to do it? (I'm in Glasgow) and if so what do you ask? ie: If I keep the case off to check install all looks ok, physically confirm the screws / fixings used for hanging are adequate, flue is properly fitted etc?? What would you want to check? (If it's relevant it's a regular condensing (probably glowworm likely use direct rear flue option) replacing a regular wall hung in kitchen..)
I did find a local company but they were wanting to charge almost as much as putting it in. (Which I also understand!) What sort of charge is reasonable for those of you willing to commission one?
Is there anyone in Glasgow area willing to give me a quote and do it?
Many thanks folks..
For others reading this, I think diy installs are a bad idea and things like wickes diy install leaflet are irresponsible and suggest anyone who can hang a shelf can hang a boiler. I like the no advice to diyers on gas policy, well done diynot. I won't be asking for advice on the install
Many thanks folks..
