Hi, I'm new to this forum and would appreciate any helpful comments on the following problem.
I have just had a new Worcester Bosch 30CDI boiler fitted and the boiler seems fine after just over a week working, but in the bathroom next door, the shower wouldn't work properly. I needed it set on the lowest water pressure and the hottest temp setting to get it just warm - couldn't get it hot at all, and when it was switched off, the water kept dripping, which it didn't do before the boiler was fitted. The plumber said we needed a new shower and so we had a Mira one fitted that he recommended to us. The problem is, now the new shower is fitted, it is dripping more than what the old one did - example, I did a test to see how much it dripped, and placed a 1/2 pint glass under the drip, and it filled within 15 minutes.
I have also noticed that when the heating is on, and the shower is dripping, that the boiler pressure creeps over the 1.5 bar mark. Is this pressure ok, or is the drip causing the pressure to rise? Also, what can be done to stop the drip? I am not technical when it comes to boilers and plumbing as you can tell! Please help, the dripping is driving me mad!
