I have checked through some similar posts on wiring up ovens but I just wanted some thumbs-up, please
This single oven is to replace a previous faulty oven, it's a Bosch
http://www.boschappliances.co.uk/products-detail-ovens.aspx?id=36
It does not come with an external felx or plug and the connection will be directly hardwired to a dedicated circuit for the oven. This circuit does not terminate with a plug socket but three terminals for earth, live and neutral.
I have the correct cable, I checked... a code stamped every 10 cms along the cable's length is as per instruction manual (I forget the code); in fact it's a cable for a PC which will be stripped both ends to the correct length!
So...
1/ Turn off circuit for the oven at fuse box. Turn off dedicated swich for oven on the wall.
2/ Using flex, wire the terminals on the oven to the terminals on the wall, like for like, earth, neutral and live.
3/ Turn on circuit for oven.
Seems straightforward, is there anything I should watch out for?
Thanks in advance.
So...
Thanks in advance.
