Last year I completely some wiring of AV equipment on my new build house. Most of this wiring involved using access holes in the floor boards to pass cables underneath (see first picture below). Part of this involved creating small holes through chipboard that linked the joists together.
At the time I asked a builder on site if making holes in the wood was ok. He stated that the load bearing part was the joists and that the chipboard between was not load bearing and was to insulate against noise and heat loss. I also observed that the builders themselves had made several holes through this wood (see picture below).
Today I posted some pictures and summary of the work I had done and another user commented was drilling through this wood correct. This rang alarm bells and therefore I just wanted to check with everyone if making small holes to pass cable though in the chipboard wood between joists was ok?
Thanks for any comments.
Gary
Access Holes:
View media item 30655
Existing Holes From Builders:
View media item 30661
Gary
Access Holes:
