C
compheat
I need a bit of info regarding using 10mm plastic on new build property.
(1) when you put the drops in for ground floor rads do the pipes require to be in capping ? Plasic or metal?
(2) where do you buy the wall plates for use behind the rads to divert the pipes to the valves.
and last question is it common practice to bring the pipes down in the centre of the rad.
