- Joined
- 7 Oct 2009
- Messages
- 7
- Reaction score
- 0
- Country
Hi all,
We are having a house built at the moment and I am about to start boarding out my loft and have a couple of questions. I am a complete novice so some of the questions may be very obvious to some!
I have searched through other posts on these subjects but can't find the exact info I need.
Here goes:
1. I aim to use 22mm thick boards, but how do I go about selecting which screws I need? ie what diameter and length should they be? The joists are 14cm deep so there is no problem regarding selecting a screw that is too long, but what sort of length should go through the boards to the joists?
2. When screwing the boards to the joists, obviously I want to use countersunk screws. What is the best way to countersink the boards? Is it simply a case of positioning the boards and then drilling through with one of these drill bits that has a countersink included?
3. Similar to question 2 above I need to batton the rafters to get the required depth for my insulation. The rafters are 18cm deep but I need insulation 26cm deep.
Thanks for any advice, all is welcome!
Here goes:
