New build shrinkage
21 Jun 2020
We purchased a new build around 12 months ago. House is about 18 months old now
How long would expect to keep seeing shrinkage?
I’ve re caulked out front door 3 times now and it keeps cracking.
I’ve used shrink resistant caulks etc
What type of caulking are you using? Some of it is pants in terms of flexibility, UV resistance etc. Not saying you should mask a problem, however if it's just natural settlement try a better sealant.
I’ve used Geocell and Everbuild Caulk Once
You need to use CT1, it is very flexible, and paintable. Also get a can of the solvent, helps to spread it well.
I had some doors that kept cracking where the plasterboard met the frame, but 3 years after using CT1, it's still looking good.
