New Build - T&G Plywood Vs TG Pine Floorboards
11 Apr 2007
Aberdeen
Gents
Given the choice in a new build - timber frame construction - the upper floor - which type of flooring would you opt for ?
24/25mm thick T&G Plywood or 24/25mm thick Pine T&G Floorboard ?
Cheers !
I would probably choose the pine as it could be stained/varnished to give nice finish without paying more for engineered or laminate flooring.
As it is a new build, you should have good thermal and acoustic insulation beneath the floor.
Regards
