Hello,
I live in a new-build timber-frame detached house. The construction is fairly simple, timber frame clad with OSB (which then has some kind foil on the outside). On the outside is a brick wall. On the inside there is insulation (some kind of rock wool) with a plastic sheet vapour barrier on top followed by plasterboard.
We had some problems with mould in the ensuite. I've now scrubbed it all off and redecorated with some more suitable paints (Zinsser anti-mould matt on the ceiling, 'modern emultion' from F&B on the walls). What I can how see when I am showering is that the walls are dripping wet for hours - the fan in the wall obviously isn't up to the job so I'm adding an MF100S inline fan.
When up in the loft, I've noticed that the vapour barrier is stapled to the top of the ceiling plasterboard. There is a condensation built up under it. Do I need to be particuarly worried about this? I am going to make sure the insulation covers over the top and get the ventilation sorted.
