Evenin'
We plan to make a Carport in the back garden approximately 3m by 6m. It will be just after the gates that separate the drive from the garden. The canopy itself is most likely to be polycarb or corrugated plastic sheets on a timber frame. The back 6m will sit on an existing 2m high brick wall and the two front corners are likely to be supported on thick timber posts. Straight forward DIY so far...
The problem is that apart from the back wall it has to be completely open so we can manoeuvre cars in through the 3m opening near the gates and out of the 6m front side. What can i use to support the roof between the two post on the front? I was thinking of 2"x6" joist but not sure if it will eventually sag across that 6m distance. An RSJ or rolled steel lintel seems a bit hardcore though.
Would appreciate any thoughts.
Jas
Jas
