In July, we finally got rid of a Baxi condensing boiler to replace with new Glowworm Micron 70FF plus new rads. The system was flushed with Fernox and has been refilled about 5 times. We had problems at first with all the rads getting red hot upstairs and not down...plumber changed a bit of pipework, then no hot water at all...hep pipe to cylinder kinked...plumber changed it. We've had three pumps since July, this one being a heavy duty. There are valves fitted at the flow-pipe and return pipe at the boiler and one fitted next to the cylinder. We've had banging in the boiler, which we were told was air (didn't shut down the boiler tho) but by the beginning of the week this had gone and the boiler has shut itself off every morning this week.
Yesterday in this long saga we had two rads which were not getting warm,flushed through and the valves checked. The plumber closed down the bypass pipe a bit to stop the hot water rushing up into the overflow tank in the loft. He also got rid of some air.Everything nice and cosy yesterday evening but the boiler shut itself down once or twice. The boiler had to be rest this morning but only took one attempt unlike the rest of the week when we had to nurse it. Rads soon warmed up - but this evening upstairs was red hot, downstairs rads cool or just barely hot at the top (room stat set to max, boiler on halfway btwn min and max- or it shuts off) and the pipe to the central heating refill tank was hot again.
I'm thoroughly fed up of it. Any ideas or is the nearly 3 grand spent been a waste of time?
