I am having an inch thick solid oak tongue and groove flooring laid onto joists, over insulated concrete on the whole of the ground floor. First I must lay central heating pipes. It's an entirely new system.
Is it best to use plastic or copper for central heating? What size? Should they be wrapped in anything?
Once this floor is laid it won't be able to be lifted to gain access. I understand that it's a bad idea to bury a join where it will no longer be accessible. But I also understand that a central heating system is laid in a kind of "branch" system, rather than in a "ring" sort of system, with the flow teeing off to each radiator, rather than looping from one radiator to another. Therefore joins under the floor seem unavoidable. What is the answer?
Finally, is it legal to lay your own central heating pipes and then just have the Gas Safe plumber connect them up when he installs the boiler?
Many thanks
zebra
Many thanks
zebra
