Hi I have an old Vokera Flowmatic which Bgas say needs to be changed and Npower will not repair it.
The boiler comes on and sometimes cuts out.
BGas came to repair it as i have homecare 400. They did the first inspection and said i need to change it although it was working.
I have tenants who refuse to have it repaired.. Bgas say parts are not available and its had its day.....
So i need to change it.....i need something which will not breakdown and one that has excellent emergency cover as i need that to save on homecare 400(20x12=240 quid/yr). Is there a boiler company that will cover the boiler and come and fix say next day.....as my tenants can be demanding....
I need a boiler which has good aftersales and support as i won't be using npower/bgas to cover the call outs.... I will still need to cover plumbing/drains.
The installation will involve boiler swap and changing the copper pipes leading to the RADS as they are pencil thin type.
The other pipes are 22. and 15mm. Some Rads only have one pipe on one side whereas others have one on each side.
How much should labour be to Change Boiler and change copper pipes to 15mm leading to RADs(SEVEN RADS).
Should i change the pencil thin pipes so i can swap RADS later when i move into house myself? Or would it be best changing everything now, or does the thin pipes make no diff would be best left in with boiler change only.
Thanks,
Adam
Thanks,
Adam
