Hi there,
Had a new WB 25i combi installed in Sept 2018 to replace an old WB combi (exactly same setup). Had all lockshields and Valves replaced at the same time.
A month later I noticed the pressure had slightly dropped from the original 1.5 and noticed a very slight leak on the connector to the condensate.
WB came out and replaced the part and another inlet as slight whistle when using hot water.
Solved I thought however a month later I noticed the pressure had dropped approx to 1.1 so I topped up however reported to the installers as shouldn't be topping up so frequently. They checked all the lockshields and valves, no obvious leaks or damp patches anywhere (the pipes are vertical in the walls downstairs).
Did the balloon check over the PRV exit outside over a few days to be sure - with no water at all.
WB came out to check the boiler again and couldn't find anything obvious however replaced the heat exchanger just in case.
I am now monitoring the pressure, however next step will be to isolate the boiler for a few days to see if it is the boiler or the system.
Any other ideas or how to find any potential leaks?
