Just had a new Ariston Combi A HE Condensing unit fitted which is nice enough but not for the upstairs taps. The boiler is fitted in the kitchen and the hot tap in the kitchen works perfectly at basically mains pressure, up stairs in the bathroom (directly above the kitchen) tho it drops off to a trickle despite the down stairs mains pressure. The cold taps in the bathroom still have high pressure(ish) tho, certainly there is a reduction compared with the kitchen sink but not like the drop off of the hot water feed.
Could the problem be that from the boiler the hot feed to the bathroom is a 15mm pipe run, would swapping this over to 22mm make a difference?
One other question re: Combi's, having never personally had one before is it normal when someone opens up a cold water tape else where the hot taps basically turn from there normal trickle to a slow drip?
