New combi fitted, query bath tap temp
6 May 2007
Lincolnshire
Sorry if this has been covered before, have searched but not found an answer. have just had new combi fitted and old system removed (loft tank,cylinder etc ) Question is why are all hot water taps scalding hot apart from the bath tap ,from looking around on here it seems to be a presure issue ? or could it be because its got a 22mm feed and all other taps are 15mm . Am not worried as its plenty hot enough for a bath but am curious as to why ? Thanks all
more open the tap on 22mm the lower the temp will be
try opening the tap only half way.
IMHO ALL hot feeds from a combi should be a maximum of 15mm
but then IMHO all combi's are horrible things so what do I know
You have a small combi (probably a 24) which is not able to keep up with the supply for the bath. Nothing to worry about.
