Hi - I am looking to replace my boiler. Initially I was advised the water flow rate coming into the house was too low for a combi (only had around 12l/min).
However, I found out today that the stop cock was not fully open. With the stop cock open I get 21l/minute.
I am a little confused on measuring pressure as I have had comflicting views from plumbers. I have taken 2 measurements:
1) Standing pressure - this measured 3-4 bar and was measured at the outdoor tap.
2) Working pressure - this measures 1.5-2 bar and was measured on the outdoor tap with another mains fed tap running at the same time.
The house has a 2 x showers.
With these measurements would a combi work ok delivering 2 acceptable showers? I was thinking about a worcester 42 CDI? If not the alternative is to stick with the gravity feed system and add shower pumps.
Appreciate any thoughts.
Cheers
James
Cheers
James
