Hi.
Could someone on the board assist please? I have just had a composite (Solidor) entrance door fitted - the design is with a single sidelight. The door is 950mm wide and the overall width of the entire door/sidelight frame is 1480mm. I noticed when I got home from work that the door wasn't sitting in the frame correctly and upon further investigation, found that the sash was in fact bowing by approx 5mm in the centre. Further investigation has found that there is no reinforcement at all within the sash and as a result, there is quite a bit of movement when closing the door. Of course, when fully locking the door, the top and bottom hooks help to straighten the bowing but not fully. The profile is Rehau and having done a bit of research, it would seem that they use a man made reinforcement (Werbar) - although in my case, no reinforcement is present at all in the sash - but is in the outer frame. Is I have checked and the frame has been correctly fitted and the bowing is not as a result of tight packing. My question is, I have bought a Secure by Design door/frame, also PAS23 & 24 but don't expect such movement in the sash and also would have thought it should be reinforced. Am I reasonable to expect this? Does SBD / Pas23 & 24 specify that there should be reinforcement?
Any assistance would be most appreciated.
Thank you.
View media item 78787
Thank you.
