new cooker hood (extractor)
5 May 2004
lo need a little help installin a new cooker hood
do i have to connect this to a fused connection unit (fcu)? what fuse would this need? and the hood i have has only the live and neutral wires no earth how do i connect it in the fcu?
thanks andy
note from the instructions:-an all-pole disconnection switch with a minimum contact seperation of 3mm must be included in the fixed wiring in an easily accessible place
yes use an FCU and a 3 amp fuse, as you only have 2 wires you dont have an option, it must be double insulated (square within a square symbol)
i can connect the fcu as a spur from another socket thats on the ring but what is double insulated (square within a square symbol) can u explain in more detail plz
thx for reply m8
double insulated appliances don't require an earth the exact reasons as to why are beyond the scope of this discussion ;)
any double indulated applince should be maked with a symbol that consistos of a square within a square and will have 2 core flex
Basically the electrical bits are isolated from the casing & end user, thus not requiring a connection to earth.
If your anything like me, and dont like points on show, you could also install a socket outlet mounted high level above your units and plugged the hood in (same goes for FCU)....or from the lighting circuit....
Just a few other options thrown at ya'.......
i would go with the high level single socket and a plug on the extractor so in a few years time if the extractor burns out it will be easier to unplug it and remove than opening up the fcu to disconnect
Although some install instructs. ask for DP iso, not s/o.
do they have 3mm separation?
I sound a bit a*al, but some manufacturers get picky if their gear is not installed to their say-so.
fingerjabber
I have just done this job a few weeks ago. I used a 3amp fused switch and run a spur up the wall from a normal socket and yes my fan only had a live & nuetral aswell. my only point is, you can't spur from a spur
