New Doors not closing
23 Aug 2005
Last year we had new doors and frames installed (ex authority house approx 35 yrs old - non standard openings) the thing is half the doors do not close properly, they close with pressure but then there is strain on the door handle/catch and at the top of the doors. I am starting to see strain in the panels. We employed a "professional" to do this (not DIY) Is there anything that can be done (apart from calling the "professional" back). At the time I think he said something about the openings not being plum.
It's quite common for openings not to be exactly plumb. It's just one of those things that fitters are supposed to overcome. I assume the company concerned were registered with FENSA. If so, they must provide you with a garantee/warranty, and have indemnity insurance to cover the cost of any remedial work required.
wonder if he meant internal doors? (In which case fensa does not "apply")
:oops: You're probably right. Just noticed the use of plurals in the post.
If these are wooden doors, they may be inclined to swell or shrink, dependant on prevailing humidity. You could always have a go at it yourself. Sounds like just a bit of planing involved.
Thanks for the advice, but concerning having ago myself, how do I do that then? How do I get my doors to hang plumb to the openings? Many thanks
You don't actually aim to get the doors to hang plumb. The main objective is to get the doors to fit the opening, into which they close. Ideally this opening is plumb on both sides, sitting above a perfectly level floor, with the top of the frame being perfectly square and level. If this is the case, once you have fitted the door, it will be plumb, if the opening is not plumb, c'est la vie.
Having another look at the description you have given above, I suspect that your doors may be "hinge bound". This gives a characteristic springy feel to the door, as if you are levering against the will of the hinges. Basically it means that the hinge edge of your door is meeting up with the door frame, before the handle side of the door has reached it's resting point. There are several possible causes for this:
If the screws used to hold the hinges onto the door (or frame) haven't been screwed all the way home, or they have the wrong heads for the hinges, they may prevent the hinges closing all the way. This may be overcome by replacing the existing screws with slightly longer ones. (if they have worked loose, simply tightening them is unlikely to prevent the problem recuring).
If the hinges have been recessed too far into the edge of the door or, (more likely in your case), it's frame, this will cause the edge of the door to be butting upto the inner edge of the frame, before the door is completely closed. There are various ways you can go about rectifying this problem. Quite often it is caused simply by years of paint that have built up on the frame. This, in turn, increases the effective depth of the hinge recess. Taking the paintwork back to bare wood and priming and repainting, can often sort the problem out.
If, on the other hand, your doors are catching elseware, you simply need to close the door, while inspecting carefully from outside, and marking where it is fouling the frame. You then just plane down the door along the edges, where the problem occurs.
TexMex, thanks very much, that all makes sense, so off I go. Will post how I get one. Many thanks
