New Double Glazing for wooden windows
8 May 2007
Hi i have a old house with hardwood double glazed windows approx 10 years old 12 panes in each window each approx 24cm x 27cm. many of the small panes have misitng and require replacments they are all held in using putty. I also intend to stip out all the good panes and re-furb the windows including re-staining.
My questions are
Q1 best place to buy the glazing and what prices should i be looking at
Q2 Will they have clips under the putty holdining the glass? If so can they be re-cycled or do i need new and where do i get them?
Q1 - Ring around and get quotes from glaziers - ask them if they make-up their own DG units. If they don't, move on. Prices for DG units can vary tremendously
Q2 - There will possibly be plastic glazing packers in there as well. I'd just get new ones as they cost pennies
Scrit
Some firms will charge proportionally more for small units. Ask for their per square metre price and whether there is a minimum size charge.
Don't use putty. Use glazing tape and wooden bead. The unit manufacturer will probably sell rolls of tape - its a double sticky sided foam. For small units you probably need tape that is 3mm thick and 12mm wide (it comes in a great variety of sizes).
