New double socket in garage?
5 Mar 2011
Cleveland
Hello to everyone out there!
I have a rcd single socket in my garage and it is the same size as a double socket.
The button on the rcd does not lock in on position - it is just springy however it does actually work intermittantly. Today I was plugging in an extension reel, which was very difficult (tight) to plug in and the rcd protecting d/st sockets tripped. (Fusebox under stairs in house)
I have a few questions:
1) Can I discard rcd socket and fit double socket as I already have rcd in fusebox?
2) Would this be safe using power tools from new double socket?
3) The light switch in the garage is taken from back of socket- is this usual-and safe? Also is it usual for garage socket to be on house ring main like this?
Many thanks in advance
:D [/b]
If the socket is already protected by a 30mA RCD then no need for an RCD socket. It is quite normal (although not ideal) for a garage socket to be on the house socket circuit.
The garage lighting should not be fed from the socket circuit unless there is some fusing down due to a reduction in cable size. Is there not a fused or switched fused connection unit in place also ?
Hi Ricycle and thanks for reply
There is no FCU in garage just rcd socket feeding light switch feeding 1 bulb.
I do have a crabtree FCU with appliance marked in writing - will this do if I put a 3 amp fuse in it?
TIA
It will be ok as long as you follow the marks correctly on the back of the FCU. Any problems come back :)
