New en-suite waste question
7 Dec 2011
Does this comply with building regs.
Adding an en-suite next to a bathroom using a common pipe.
Image in album
Venting is indeed the key - flushing either WC could remove the trap water seal from the other pan.
An AAV on the furthermost WC should suffice. However, best to check with your LABC in case they have any further views on the matter (some have been known to be quite anal and insist upon separate runs to an inspection chamber, which make one wonder why tee-s are actually available :confused: :rolleyes:)
