- Joined
- 17 Feb 2006
- Messages
- 375
- Reaction score
- 2
- Country
I bought a new flexible filling loop to replace the old one, as per this thread:
//www.diynot.com/forums/plumbing/leaking-filling-loop-and-two-of-them.361230/
Just looked at the new one and it's the opposite way round to the old one, by which I mean:
Old one, DVC on cold mains supply, with arrow pointing to the braid, isolator valve on the CH return end.
New one, DVC has arrow pointing away from the braid etc. etc.
Then, I looked. I'd assumed that the connection from the valves to the braid is something like the tap end of a flexible tap connector, with a washer and everything. But it looks like a compression joint to me, same thread, shoulder for the olive. Only difference is that the braided thing has an O ring and goes inside the valve body.
So am I right in thinking that I can connect these whichever way round I like, as long as the arrows on the DCV/Isolator are pointing in the direction of flow?
Two reasons:
1. The only thing that's actually leaking is the Isolator valve, from the tap spindle, as far as I can tell. So that's all that actually needs replacing.
2. Once I've worked out how to isolate the flow and return on the boiler itself, I can use the isolator valve as a drain off point on the return, for reverse flushing the system (there is ALSO a built in filler which connects mains to flow, and there's a system drain on the flow, for the opposite flush). Ecotec Plus 831 combi.
Thanks.
Two reasons:
Thanks.
