- Joined
- 5 Nov 2021
- Messages
- 1
- Reaction score
- 0
- Country
I moved into a flat in May this year, can't figure out the heating and hot water system. I've tried the FAQ's and searching but can't find anyone posting a question in exactly the same scenario. The letting agent has been useless.
The flat has a Dimplex RXPW4 pilot wire controller in the hallway, the lounge and bedrooms have Dimplex EPX1000 and EPX2000 panel heaters mounted to the walls, the bathrooms have each got a towel rail mounted on the wall. The towel rails have a dimplex pilot wire box on the wall at the bottom. The panel heaters and towel rails all have 2 switches next to them on the wall (like a light switch). One is power to the unit and the other seems to be some kind of 'constant' or override switch which makes the unit ignore the slider thermostat on the panel heaters, no idea what it does on the towel rail.
There's a Range Tribune HE hot water cylinder in the cupboard in the hallway, it seems to have two immersion heaters in it, one at the base and one towards the top of the cylinder. There are two switches (like a light switch) next to the boiler, both unlabelled, one at waist height and the other at eye-level. There's a dimplex pilot wire box on the wall next to the switch at waist height but no wire visibly coming in / out of it.
From the research I've done today I think the switches near the cylinder control the two immersion heaters, one to be left on constant and one to act as a boost? I can't see a timer anywhere. There's one consumer unit in the same cupboard as the cylinder and we have one electric meter downstairs in a communal cupboard. I'm on a standard tariff with SSE, they've never mentioned economy 7 to us.
I've turned the eye-level switch next to the boiler off today because I think i've had the 'boost' immersion on since we moved in, I want to see if it impacts our electric bill.
I'm trying to figure out:
1. Am I correct in my above comments re: 2 immersion heaters. Is one for constant use and is the other a 'boost' ?
2. How does the hot water cylinder heat up? The pilot wire system was completely disabled until this week when we've started trying to use the wall mounted panel heaters. If I am correct re: boost, I guess we've been getting all our hot water on boost since May.
3. Could the cylinder be linked to the pilot wire controller? It has 4 zones. Zone 1 seems to be the lounge heater, zone 2 is the bedrooms, zone 3 might be towel rails but i'm struggling to figure them out and zone 4 seems to do nothing.
Apologies for the essay, I've tried to be as thorough and descriptive as possible but I can provide pictures if that would help!
