Hi All,
I've just moved into a flat and need some advice on a) how common/uncommon this setup is these days (i.e. how much we should expect out landlord to change it and b) what's involved in changing it c) how it actually works..
We have a boiler (Potterton Profile 50e) in the kitchen, and an immersion heater in an airing cupboard approx 20ft from kitchen through the sitting room. There is a Honeywell timer control for turning the heating and hot water on and off - it looks like the heating control on it does nothing, and the hot water control switches on/off the boiler in the kitchen which then turns the heating on *and* warms up the water in the immersion heater tank. There is no thermostat anywhere, and I haven't worked out a way to see if the immersion heater in the tank can warm the water up on it's own , or have the boiler in the kitchen make hot water without the heating coming on. The only other controls are a mains style on/off switch by the boiler and immersion, and the simple dial control on the front of the boiler.
My main problem is that there is no hot water without the heating being on! Is that normal? Also the immersion heater looks like it's in a mess - has it probably been disabled? Should the boiler be producing instant hot water?
Thanks for any/all help advice!
m
m
