Im planning on replacing the old split/broken/warped floorboards (approx 25mm thick) in a bedroom 3.6x4.5m) with either 32x150mm (28x137mm finished) PTG white wood floorboards, 18mm ply (shimmed up to 25mm), or 25mm ply.
Floor joists are 457mm centres, and 83mm wide.
I can't decide which to use. Ply has the advantage of being able to easily lift sections in the future if I need access to wires or pipes.
25mm ply is expensive and heavy ... I'd need to get the timber merchant to cut the 12x8 sheets in two longwise before delivery. It's stiff enough that it wouldn't need noggins to support the long edge.
18mm ply would be cheaper and easier to handle, but might it flex on the long edge between joists?
Should I leave a gap (1-2mm?) between the long edges of ply, and fill it with a flexible mastic?
Would the floorboards need acclimatised in the room for a while before fitting? Is there a risk they will bow?
I plan to carpet this room at some point.
Thanks,
Ian
Thanks,
Ian
