I'm putting in a new front door frame but cannot anchor the sides as there are glass block walls either side of the opening. The existing frame is rotten on both sides where it meets the cill (just poor maintenance by previous owners)
As the opening is full height 90" but my door is 80" high, should I get a pre-made frame to the door height (and extend it 10" - how?) or the opening height (tricky as I haven't seen any off the shelf for this size). Something like this:
Also I've seen a lot of comments about not drilling/nailing into the brickwork through the cill... but I don't think I have any choice, what should I be wary of? Also, what's the security like of a door anchored only at top/bottom?
And I'm puzzling over cills and weather bars... current door has a little metal bar in the cill but when I rip out the frame, I'm going to put a new cill in. I was thinking about using a Stormguard "SLIMLINE" thing, would that do? And do I need to have a sticky-out bullnose type strip (a "weatherstrip"?) on the bottom of the new front door or can I leave it flat?
All will be exposed to the elements, particularly given this summer
