I am installing new kitchen units and I am not ready yet to choose and instruct a gas safe fitter to connect the (4 burner) hob gas line but could do with some advice on what is usually practicable for a fitter.
I have installed a straight run of new 15mm copper behind the units from the 600mm base unit that will have the hob mounted and through a wall (sleeved) to where the fitter can easily connect to the existing 1/2" bsp iron pipework.
If I fit the worktop and hob, is he likely to be able to work in the 600mm space to make all the pipework connections inc a local tap.
Or are most fitters going to want to fit pipework to the hob while its not fitted and come again to connect to the run in the base unit.
View media item 18314
View media item 18315
I saw mention of using 10mm microbore for ease of fitting in a previous posting, is this a consideration or is it likely that 10mm would really be too small?
I have a combi boiler but thats on its own pipework back to the meter so this will be the only gas usage on the existing house 1/2" iron supply.
