I am currently replacing some guttering. I am taking down old Hunter 112mm guttering and replacing it with new 112mm Hunter. Simple you would imagine.
Except the both the new stop end drain fitting and the new 90 degree bend fitting are longer than the old ones they are replacing.
Fitting one to the other, butting them up together, makes a piece that is fully 3" longer than the piece I am taking down, and co-incidentally 3" longer than the available space on the building.
I can't drain elsewhere and route back to the down pipe without routing the pipe across a window.
Does anyone know of a supplier of a smaller (shorter) stop end and/or 90 degree corner in 112mm guttering?
Or does anyone have a solution to this problem that I haven't thought of?
Thanks.
Thanks.
