S
Simonbeasley1
Hi All,
Have been approached by a client to supply and fit a boiler into a Grade II* Listed building.
I need suggestions of a boiler company that would supply a boiler that would utilise the existing chimney flued liner connection. Client said they are exempt from having a condensing boiler as the building backs onto the Church yard. I will be checking with local council to find out if a condensing boiler can be used providing it utilises the existing chimney flue.
so just to recap - An open flued heat only boiler non condensing and condensing options using the existing chimney (pls note will drop new liner down if required).
Do i need to supply a set of plans to the local planning office detailing the boiler & cylinder upgrade?
Thanks in advance
Simon
Thanks in advance
Simon
