We're refurbing an edwardian semi and need to spec a boiler - builder has suggested a Vaillant 937 which is physically huge.
Based on a three bed one bathroom and cloakroom house I'd guess an 837 would be OK but we're trying to build in maximum flexibility for converting the loft in the next couple of years which will include a further shower room.
Water pressure is OK (2.5 - 3 bar) and flow is around 15l/min. Supply pipe is lead so we'll be replacing that with 25mm MDPE which will (I guess) boost flow but drop pressure slightly (although the comms pipe is also lead and whether Thames Water will sort that is yet to be confirmed).
Have also considered whether an unvented cylinder would be worthwhile to ensure good shower pressures post roof conversion - space considerations would mean this would probably need to go in the loft space. Although siting it would be key so we don't have to move it come conversion time...
Any suggestions/alternatives we should look at? Is an unvented cylinder likely to be viable once we've swapped the supply pipe and can they go in the loft? We've got pretty much total flexibility as the house is currently gutted.
Thanks.
S.
Thanks.
S.
