Air source heat pump. It will be as economical as a condensing boiler and run off normal electric. Small 3 bed house with loft insulation and double glazing. 12kW should do you.
An ASHP sounds ideal when you read the specs!
The reality seems to be that their efficiency falls off severely just when you need most heat and worst the heat output also falls off too, in some cases quite badly.
The reliability and warranty length is also seemingly pretty poor too. The capital cost is much higher than a gas boiler system.
Only with under floor heating are they reasonably satisfactory! But thats very expensive to install in an existing property.
LPG is also very expensive compared with nat gas too and the storage tank is another high cost.
So if you can get a nat gas supply for less than £3000 then thats what you should choose!
Tony
