Hi
Installing a new combi system but a bit confused over TRV requirements. I believe the usual practice is to fit TRVs to all radiators except one, which is fitted with fully open lockshield valves on both flow and return to make sure there is always an outlet for the boiler. I'm also told this is usualy the main hallway radiator and /or where the room thermostat is.
Just wanted to check:
1) Anyone see anything wrong with the above before i start?
2) Towel rail valves - most of them for sale seem to be standard rather than thermostatic. I also think the standard ones look better but i'm not sure if they are ok to use? (not sure if regs are involved here, or if its ok to mix normal valves and TRVs in the same system?)
Also, if ok to use, do i then treat the towel rail as the 'boiler outlet' and fit a TRV in the hallway? (plus where would the best place for the room stat be with a setup like this)
Thanks in advance for any help
