- Joined
- 30 Dec 2003
- Messages
- 10
- Reaction score
- 0
- Country
Hello,
I am about to embark on a total refurb project on a 3 bed end of terrace house in East London. It will also be extended to the side and rear to make a decent size 5 bed house.
Background:
I've just come back from Sweden where I saw an amazing heating/hot water system, but I don't know what to even search for here in the UK...
The central unit was the size of a large fridge and appeared to be a heat exchange unit. It had two separate heat sources - a Geothermal bore and an attached wood pellet burner. Apparently similar units can also support a third external heat source (eg: solar water).
The heat exchange unit had two outputs - a closed water loop for central heating, and a domestic hot water outlet (I think there is an integrated hot water storage tank).
I think the geothermal was the main heating source and also to pre-heat the hot water supply, while the wood pellet burner was used for peak heating load if required and to heat the hot water to the required temp.
Does anyone know about this type of thing (the heat exchange part rather than the heat source part)? Any suggestions on where to look for more info (manufacturers sites etc.)?
Proposal:
I am considering the above type of heat exchanger, but fired by a ground source heat pump, solar water & a gas fired boiler, but with the added twist of limitless hot water (rather than a finite supply in the storage tank). I don't know if this would be direct gas heating (like a combi boiler) or if the gas boiler just has to be powerfull enough to keep the heat exchange tank hot enough to heat the water as it passes through or even if it's possible at all.
Any alternative ideas, links or suggestions welcome!
Thanks.
Background:
Proposal:
Thanks.
