Hi - I have just had had a new Honeywell V4073A1088 valve installed (about 2 weeks ago) to sort out a heating problem I was having.
The heating refuses to switch off - even when slider switches programmer on boiler are set to OFF. I have had the programmer changed on the boiler - and it makes no difference - ie. the heating will not switch off - unless boiler is set to hot water first and thermostat dial is turned all the way off.
It has been suggested that the V4073A1088 valve could be stuck 'open'? I have checked the lever on it and it is set constantly to AUTO. I tried to move the lever manually - and found it extremely easy to slide back and forth. Could this problem be linked to the spring lever not installed properly?
